I don't get the problem with benchmarks. Isn't it just like Turbo mode on my i7? It has a "normal" speed, a lower "idle" speed for power saving, and a "higher turbo" speed for when it needs it.
It's dishonest and HTC is the only manufacturer left doing this.
But it's not boost mode, it basically just forces the performance governor which locks the device at the max clockspeeds while running a benchmark, which is not how normal applications or games are handled so the result is false and does not represent normal usage.
Honestly who cares about Phone benchmarks? You buy a Phone so long has it does the tasks in hand Great. Do people really buy based on that information?
I can tell you one thing M8 is anything but slowit kills everything you through at it. The performance for from me coming from HTC OneX what was already fast is mind blown.
Battery life is unreal for me the best I have seen in a phone, I getting charge cycles like you see in a laptop avg 4-5 hours screen time.
Based on a single benchmark result? of course not. But it doesn't change the fact they are cheating, 3DMark has already delisted the HTC One M8 because they also found HTC to be cheating.
The HTC One X was slow, I doubt you would even be able to tell the difference between Snapdragon 600 and 800.
