Pretty much instant here. How are you connecting to it? Wired/wireless/home plugs?
Wired/home plugs.
But never had a issue in the past....
Guys, When accessing the router Via IP Address
192.168.0.1 - Does anyone else's take about 5 mins to access the page?
Also been getting some terrible speeds!!! I'm on the Fiber pro, and average connection for me is around 58mb down and 19mb up. but lately I'm lucky if I ever get 25down!
Any ideas? I've contacted them and they have say it would be the CAB, so engineer is attending.. just wondered if anyone else has had this..
And to top it off, wife is account holder she's in Tenerife and they wont speak to me!
My wife is the account holder, as long as you have the password they'll speak to you.
I sorted everything out.
No password set up on account only the security question.
just want to make sure I got the setup right and the issue is in the line not being active.
the home phone works fine, the BB doesn't. it's a new order that I'd had about 30 days worth of trouble with.
so RJ11 DSL cable from the wall socket is plugged into Openreach modem. one ethernet cable connects LAN1 on modem to bottom port of SR101. second ethernet cable connect top ethernet port on SR101 to ethernet port on the laptop.
192.168.0.1 status summary = broadband disconnected, wifi enabled.
btw does the SR101 include fibre router? I've seen that it's got DSL router, so in order to use fibre, you must use the Openreach modem, is that correct?
I have used the BT Modem but not sure of the tp Link settings?? All lights are on
Have you tried another server, out of interest
Anyone for a DrayTek 2830n working or got a link to setup instructions please
