You plan on just running P95 on your computer? That's all running P95 proves, is your computer is stable....running P95.
Not prime 95 again!! Prime 95 who cares!!!
Intel surely are on some very shaky ground then, considering their marketing claims?TIM is the same we delidded some in Taiwan. The major change is in the power delivery which for me has made no difference to overclocking. Infact my 4770K are better...
Processors were designed to do math, Prime95 is math, show me a CPU that fails at math at stock speeds, it would be deemed as faulty and thrown away/sold at a lesser speed.
Anyone who wants a system that works as intended and isn't interested in willy waving, there's a lot of people who take stability seriously you just don't see them posting as much as the overclockers who tend to brag a lot.
!I will be excited about it when and if I find 6.5+ 3D chip or 6.7 2D chip. I am sure they are out there as with 4770K but for me so far DC is not looking great. My quest starts early next week.
I've found the same thing in the past. I've tried running my system for gaming on max overclock and there's nothing more annoying than the system BSOD or CTD after an hours gaming. Which is what usually happens if my system is not 100% stable, such as Prime95 stable.I dunno, in the past ive tried just running stuff like IBT and its passed, but then failed in prime95. And when ive tried to use my pc without running prime it fails and gets bsod. But once I run prime95 afterwards my pc seems fine, never get any bsod.
Each to their own I guess![]()
I'm using a dark pro 3, all stock. Was sitting at 70c under load last night, stock speeds. Seems warm to me??
Hmm. I really don't want to pull it all out again. I used the thermal paste which came with the pro 3, wondering now if I should have used some silver 5 i had sitting around.
Its in an matx case but its got two fans blowing air in directly on to the hsf, and a 140mm exhaust.
I will need to investigate![]()
If it can run P95 then I've found it can run anything, even very system intensive games like Civ 5 or a fully modded Skyrim for hours without issue. Which is why I built a high end gaming system....
they sold out already...
