The 29" I bought as spare is the 29EB93-P, not the one you mentioned! By all accounts the EB93 appears to be just fine as far as an 8bit panel goes and performance.
Ah! Damn LG and all these slightly different versions/model numbers
I presume it would be using the same panel as the 29um65 and the 29eb53-p......
This is certainly a mess. I've never seen a monitor people want so badly, yet can't provide stock or quality.
I really hope this is a new revision and everything is sorted out.
Between this and all the issues with the SST Ultra HD displays, there are very few choices for me.
I wish LG had a rep on this forum, and others. They'd see the market wants their products.
Yup, it is coming up to 1 month now since I bought the 29um65, during that time, it was out of stock for a week or so.
Personally I have no interest in considering any non 21.9 aspect ratio monitors now and most certainly not 4k (due to all the problems with it + needing 2 top end dual GPUs to run games on mostly max settings at an acceptable frame rate)
Vertical height is ridiculous less than a 23" 16:9 screen. Sound quality is also pathetic & the onscreen controls are way too sensitive.
