His temps are pretty ridiculous, wonder what his ambient is
50c load temps? Mine was mid 70s with custom water rather than AIO.
cpu-z should be more accurate? bios wont add on llc level
My game room has good airflow,but I think I could get temps down a little further
You can only cool so much with better airflow, you're ultimately limited by ambient temps. My room currently is 23c, and my 4790k is running 45c @idle.
Really low fan speeds, but still running at 22c delta T.
P95 will load the CPU, CPU-Z should state the load voltage.P95 would show volts
45c on idle? You kidding?
Is that idle or under load?1.056
Don't need to under volt. Not really into OCing anyways.
its still hot tone?
sitting here my 3770k is skipping between 29/31/31/30 cpu fans at 700 odd rpm turn up your fans
@five stars you need to use cpu offset,only add small amounts so maybe +0.010v and try high level loadline calibration,then see what load cou voltages are and add more or reduce offset
its still hot tone?
sitting here my 3770k is skipping between 29/31/31/30 cpu fand at 700 odd rpm turn up your fans![]()
I will be 45c if its not downclocking in volts
Yeah, i know it's hot
Doesn't bother me, 4.6 and just slapped 1.3v on it. Seems stable, and temps are underload around the mid 60s touching 70s on the hotter core.
Better than stock, where it wanted 1.36v, and no...not turning up my fans, they're annoying any louder. To the point i'm seriously contemplating ripping this computer apart and changing everything out again. Also, idle voltage is 1.25v. So not comparable to Retro, who after all this quoted his bloody idle voltage and not load voltage!!!
@retro, what's your load voltage for 4.5Ghz?
