4790k retail Back in stock![]()
^same core volts at stock on mine. Which bios version?
Gaming on mine just now, temps are so much lower at 4.7ghz than my old 4.5ghz 4770k. Auto fan results in a highest core temp of 61c. Same cooler, fans and settings on the old chip would get into the high 70's. Had to set fans manually to full speed, (which was incredibly loud) to keep it in the mid 60's. Extremely pleased with this.![]()
Cheers mate.Top job m8.![]()
So if I don't already have a 1150 CPU, I'd need one prior to using the 4790k so I can do the Asus update? Well that sucks.![]()
Yep, absolutely terrible cooler. I had the misfortune of having to use it for a day or so. Temps in the mid 50's at idle.Mine is here!
I'm guessing the stock fan is rubbish as always and I should get a Noctua.
