- 22 Jul 2012
- London
Personally, I'd rather have a single 7990 if staying on air.
On water though, 2x280X/7970 for sure.
Oh good shout, just remembered my motherboard lol. Single card it is for nowwhat would you do though, tri X for £290 or a 2 month old MSI Gaming OC 290 for £240?
If you can separate the cards the heat isn't that much of an issue. The problem is finding a board that will let you without dropping down to pci-e 3@4x/2.0@8x.
Not a prob unless running 4 cards in 4K.
http://www.techpowerup.com/reviews/Intel/Ivy_Bridge_PCI-Express_Scaling/23.html
http://forums.overclockers.co.uk/showthread.php?p=26562152
It's 30cm and about 1 kg. Yours is 3cm shorter.
^ You'd better hope that Matt doesn't see that post![]()
