Thanks
Cheers Shivy, I'm in love with gaming again![]()
What type of temps are you getting with 2 of those cards in a case? I'm guessing the top 1 runs a good deal hotter?
Thanks
I see, but what splits the water going into the first gpu so that there's a equal amount of water going through each block? I mean if the route is for example a few mm shorter on one route because of the way the internals of the block is machined won't the water going through the shorter one more and one route get like still or very steady flow? Rather than only one possible route where it would always be flowing, or are the temperatures pretty much identical from the two cards? Thanks![]()
Contact Corsair support, they should fix you up
Was it by any chance the caddy with the screws/accessories in?
OK got my case but 1 HDD caddy is missing
Does anyone know where I can get another one? Thanks.
Sorry about that. No worries, we'll get a replacement caddy sent to you right away. Create a ticket at Corsair.force.com and send it to me so I can approve it right away.
How are you liking your new case?
Hey guys, my new 750D build - still some work to do making things neat.
My Classy and SB z are scewed it at last. the H80i is nice and quiet. But my TX850 v2 is abit messy
You could get someone like pexon to custom braid the PSU for you, or get some cable extensions from Silverstone or BitFenix
I am interested in this tooHi guys, can anyone recommend some 5.25inch to 3.5 inch adapters for the 750d please? I want to remove the hard drive cages completely and mount my 3 HD in the 5.25 bays.
Cheers
