But we haven't got the router sent out yet!Just bought a ASUS RT-N66U in preparation of my fibre install on Friday! Is there anything I should do with the settings apart from put my plusnet login in?
Cheers
What is the router plusnet send out like, Any good? Our plusnet should go live on the 4th of august all being wellBut we haven't got the router sent out yet!
and static IP simple to add.Switched over from Sky this morning - 74/19 on a quick speed testand static IP simple to add.
One thing I'm confused about however - I have a BT person coming between 1 and 6pm today. As everything is working do I need the visit?!
No you don't, ring and cancel it as you'll be doing the technician a favour by not wasting his time.
When I changed from Sky to BT an open reach technician was booked automatically even though I knew I didn't need one, anyhow I simply plugged my router in on the day of the swap and everything worked fine so I rang BT and cancelled the appointment.
Rang plus net, bloke was a bit confused that a switch from sky just worked without issue - too late to cancel BT person but assured no charge.
8 months ago they sent me this. It's a basic no-frills router, but it was stable and would be fine for 99% of homes.
http://www.trustedreviews.com/plusnet-fibre-router_Peripheral_review
I did change it for a Draytek but only as I needed extra features only the Drayteks have.
I had a google around and it seems like lots of people have that same router! Plusnet are sending ours out over the next couple of days so we shall see.
Yes, separate modem and router (the original sky router still in its box only used to get the username/password).
Only had sky fibre 14 months so must have just missed getting their combined box (phew!)
You would have missed it by a lot longer as I'm guessing that you either have the old sagem router (which could be used for fibre in the same way the plusnet supplied router does) or the original sky hub (only the new sky hub which has been available for a few (I don't know how long a few is) months has the fibre modem included).
So once we are up and running I will hopefully be flashing it to a none ISP firmware
Let us know how you get on.
13th April (2013)
It is getting faster. Now 10GB quicker than stated!
Couldn't get the Samsung router to play nice so got the Plusnet router ordered to get things up and running.
Internet now works but only getting 40/20 speeds. Have opened a case with Plusnet and they are investigating.
