ok...
HDMI audio -
Stereo uncompressed
Optical audio -
Bitstream out
Bitstream format -
Dolby Digital
Hope this helps, still comes out of the TV speakers so you have to mute that, not sure why its different to the 360 :/
Didn't work
ok...
HDMI audio -
Stereo uncompressed
Optical audio -
Bitstream out
Bitstream format -
Dolby Digital
Didn't workjust don't understand why it's so difficult to get working. I might have to get in touch with MS support see if they can shed any light.
Have you tried looking at audio options once you are actually playing a disc?![]()
Secondly I bought a cheap soundstage. The audiophiles would have a fit but the sound is so much fuller than my tinny TV speakers.
Which one if you don't mind?
The hdmi settings are off, stereo uncompressed, 5.1 uncompressed, 7.1 uncompressed and Bitstream.
Rumours another XB1 price cut is on the horizon.
Logik L37SPB14 I think it may be an own brand for a large electrical retailer so I can't link directly.
For the price it has really enhanced the sound. The remote though is absolutely shocking!
