- 24 Jul 2009
Does the latest Nvidia driver and watch dogs patch fox the stuttering without the need for the 'TheWorseMod' or shall i still use this mod?
Its pretty much sorted for ati without any mod, should be for nvidia too.
'Fix' for 670sli = disable sli. It don't work properly.
Unfortunately not all games launch with Radeon Pro active![]()
AA doesn't make much of a difference. Temporal SMAA should be fine.
Stutter with high textures has been fixed now, so if you are still getting it then your settings are set too high.
I found this to be quite helpful - http://hothardware.com/News/Optimization-Tips-And-Tricks-For-Watch-Dogs/#!bxSLrs
Especially:
My 7990 has 3GB of memory per core, but I have managed to squeeze high textures and ultra quality out of it, but have left AA to temporal SMAA. Just have a play around with the settings, but they are probably too high.
Regarding this Im a little confused:
2GB of Video Memory
1920x1080 Resolution
High Textures
Medium Detail Settings
Temporal SMAA
The medium Detail settings bit.
There are two diffeent setting here.
Overall quality and Level of detail. Which should be set to medium?
Not really sure and I can seem to set it higher anyway...but perhaps just try both and see what works for you?
Ubisoft has just released a new update for the PC version of Watch_Dogs. According to the changelog, this patch improves performance on more recent models of cards.
Watch_Dogs just released a PC patch that includes the following fixes and improvements:
- Better performance on more recent models of cards - 770 onwards will see better improvements.
- Moved all resource creation to an exclusive worker thread.
- Changed technique used for updating texture mipmaps in Ultra textures mode.
Also, Nvidia users, don't forget to download their most recent driver
