how do you get 50mpg? i get 42.5mpg from minePretty much. Will see if I can get it to 200k. Still returns 50mpg with some heavy foot.
how do you get 50mpg? i get 42.5mpg from mine![]()
yeah i suppose i must go up hills a lot. the only time i've had it on the motorway was on the way back from picking it up and it went up from 39.2mpg when i picked it up from the garage to 42mpg. i've driven it to work all this week and it seems to stay between 42.2-42.5mpg i only do about 5 miles though so that and the fact that its quite hilly round here must make my mpg bad.Is that extra urban? Urban I get around 36-40. Extra urban I can get 55mpg if I sit at 60mph.
Pay that but get Goodyear AS2's or CSC5's, they're much better (I prefer the AS2's, they wear slower).
I recently put falken 914's on the rear, no problems.
This. I only ever use Conti SportContact 5s on mine because there's no point buying cheaper, inferior ones. I've not tried Goodyears but I could be tempted to switch.
Key-wise, you can buy a new Jaguar flip key for about £60 from eBay, take it to Timpsons and get it cut, and then program it yourself (this isn't difficult). I'm not sure if there are any other "Ford-branded" flip-keys available since I did this.
Edit: There's this: http://www.ebay.co.uk/itm/NEW-3-BUT...cessories_Safety_Security&hash=item43c46ceb53 which I'd be tempted to take a punt on.
Yeh same as the rear of mine and they look like new from wen I got the car just over a month ago. I normally like having the same tyres on my car but the main tyre places by me don't seem to have Falken tyres![]()
i've got 3 double stars and 1 baldish bridgestone on at the moment. i've got a full set of bridgestone with 5mm of tread on in the back but i need to get them fitted. my dad has dunlops on his s3 which are the same size (225/40/R18) and they seem pretty good.What tyres r u guys putting on the mondeos? I need to change a front tyre the side wall is gone. It has 2 P Zero's on front and 2 Falken's on back but don't fancy paying £120 for another P Zero
Any cheaper decent alternatives that do the job as the other front has only got a few months tops left in it also. Finding the grip quite poor in the wet sometimes.
Also battery is going on main key so was thinking of just replacing it with a brand new flip key seems as it's seen better days so how much would I be looking at for a new key? Do I have to get one cut myself and then program it?
also here is what mine sounds like with its not very quiet exhaust.
https://www.youtube.com/watch?v=ElY9s0YtZeQ
That just gave me a headache. Sorry but i would have to get rid of that exhaust asap.
Can you hear that inside the car?
that is the camera mic whilsing. i did say it was broken. you can't really hear it in the car at all and it doesn't do it if you change gear quickly. its decatted and has no silencer so it does sound beast as long as you don't lift off all the time. i just think anything is better then a normal diesel clatter.That just gave me a headache. Sorry but i would have to get rid of that exhaust asap.
