- 23 Jun 2004
- Blackburn
Those who are pushing high overclocks how are you doing this? Are you adjusting the cpu multi or the turbo multi?
My cpu will do 4.8ghz at 1.247v (posted images earlier in the thread) but im struggling getting it higher.
I'm using turbo multi, volts adjusted via LLC and all power saving features enabled so mhz and volts drop at idle.
Am I likely to get a higher oc if I disable all this and just clock using the cpu multi and run constant volts and mhz?
