@Mal, is that the case in your sig you're discussing?
I have had the A10 in a box unopened since I bought it new on the bay last year. Just never got around to swapping it over from my v1000 case.
cheers, andy.
hi
i got mine from a competitor, they have about another 30 left, it cost about 70 quid, mine is black and i've modified it quite a lot..... i might get another one for spares. i've removed all the hard drive cages and everything in the lower area too, i've fitted two 140 mm intakes on a modded front panel
the case looks great, really nice, but it's very old fashioned inside, so you'll have to remove all the cages.... you'll need a 4mm drill to get the rivets out, you will also need to cut slots into the mobo mounting plate and the panel it attaches to, to get the PSU cables in..... the 1000W PSU is a real sod to fit, so take care, the cables are a nightmare to bend around the panels..........but the mobo and the pc back plate unscrew and slide out the back in one assembly, so it's very easy to test the mobo as a separate ``work bench`` and then slide it back in !!!! this is a very clever idea
it only has one 120mm exhaust in the rear....nothing in the roof, you can not remove the roof panel, it's riveted to the end panels
but there's easily enough room in the lower separate compartment for Water cooling the GPU, because it has a 3rd intake fan down there
the other rig i was talking about is a Cooler Master, the lian is way bigger.
