No way would I want curved for desktop use.
If it was 100"+ sitting 15 feet or so away for TV and Movies then I could may be see the appeal but even then why curve it if you can see all the screen in front of you without turning your head.
You would if you used it.
You're forgetting that the monitor is so wide that the ends look slightly distorted with the way our eyes work. The slight curve fixes that.
