Backed vcore of to 1.300 and its still going ok in games. Most interesting thing is though, cpu temps must be effected by my gpu's. 2x non reference cooled gtx 780's. With the lower vcore and the cards running without a frame limit in games, temps are still in the 70's. If i limit the cards framerate the cpu temps max at 64c. Due to the coolers on the gpu's they dump a fair bit of heat into the case.That temp is fine. I only delidded mine to try and push for 4.8.
Some thing wrong with that one. what volts are you putting in.
what is the safest lowest voltage for the 4790k? (that would also boost to 44)
...........the difference is enormous
.....cpu is 27 to 30 degrees idleI use similar mobo to you (Asus Z97 pro wifi) & when i was testing with stock cooler i just put a minus offset voltage of .05(-.05) , this allowed me to use XMP settings & still keep temps reasonable.Tested with Realbench etc some light gaming & temps stayed below 80c.what is the safest lowest voltage for the 4790k? (that would also boost to 44)
Hmm, just recently installed a 4790k and the thing is crazy hot. Under Prime95 I'm getting around 96c :/
It's on a H100i cooler as well. Guess I'll try a different set of thermal paste or something.
- and now the Vcore reads right at 1.263 rather than reading the VCIIN of 1.82 ! dunno why one works when the other mis-reads, but i'm not complaining.seeing i think 1.264 vcore and huge temps, pushing 99 on core 1, 96 on cores 0 + 2 and core 3 is down at 88, that's in intel burn test and prime95
watched it run to 63 degrees while doing a heap of updates, so in real world use it's crap too
Now mobo in my main rig with my custom water cooling it runs 4.7 ghz @ 1.3v(DDR 2400) & temps are lower .
Are you running the latest bios for your board? A lot of early versions would set pretty high vcore and a higher 4400mhz cache/uncore clock. Running real bench results in a max temp of 81c for mine, 4.7ghz on 1.300v. Air cooled with a k2 and dual 2350rpm corsair sp PWM fans.
I would invest in an aftermarket cooler, the stock one is terrible tbh.Hey guys. Running an i7-4790K with IC Diamond on the stock cooler with plenty of case cooling. I'm idling in the late 30's early 40's and maxing out round the 85C mark when I video encode or run Prime/Intel Burn etc. Is this the best I'm going to get temps wise with this chip? I was running up to 100c initially but reseated and got to where I am now. I'd feel more comfortable maxing at 70c or so but don't have the balls to delid the chip.
Any settings I could try out on the board? I'm a noob but can learn quickly if I need to. I just want the temps down a bit. I'm on the Z97 Gaming 5 board flashed up to latest BIOS and too scared to run an overclock with these temps.
