Looks good.
What's the final spec?
Here ya go dude :
BTW Retail on this is £4300! £800 more than the Remedy I ordered, but the deal I had was stinking so couldn't say no!
Frameset
Frame
Alpha Platinum Aluminium, ABP Convert, Full Floater, E2 tapered head tube, press fit BB, internal derailleur & dropper post routing, ISCG mount, magnesium EVO Link, Mino Link, 160mm travel
Front suspension
RockShox Pike RC, 2-position Solo Air spring, rebound, adjustable compression damping, E2 tapered steerer, 15mm Maxle Lite, 130mm/160mm travel
Rear suspension
RockShox Monarch Plus RC3 DebonAir, rebound, lockout, 8.25x2.375"
Sizes
15.5, 17.5, 18.5, 19.5, 21.5”
Wheels
Wheels
Bontrager Maverick Pro Tubeless Ready w/TLR strips, Stacked Lacing, 142x12 rear, 15mm front
Tyres
Bontrager XR4 Team Issue, Tubeless Ready, 27.5x2.35"
Drivetrain
Shifters
SRAM X1, 11 speed
Rear derailleur
SRAM X1, Type 2
Crank
SRAM X1 1400 X-Sync, 32T
Cassette
SRAM XG-1180, 10-42, 11 speed
Chain
SRAM PC-1130
Components
Saddle
Bontrager Evoke 2, chromoly rails
Seatpost
RockShox Reverb Stealth, 2-bolt head, 31.6mm, zero offset
Handlebar
Bontrager Rhythm Elite Riser, 31.8mm, 15mm rise
Stem
Bontrager Rhythm Pro, 31.8mm, 0 degree
Headset
FSA NO.57E, E2, sealed bearings
Brakeset
Shimano XT hydraulic disc
Accessories
Grips
Bontrager Rhythm, dual lock-on
I'm confused.
