With Crossfire doesn't it only use 3Gb? Essentially mirroring it.
Yes it uses the same amount on both cards so you need to half the figure shown. Or something like that.
The game uses what you have available as a buffer. My 980 sits at a constant 4GB usage but remains smooth.
If it goes over what you have it will buffer to system ram or HDD.
yes it does Halfmad, I only use 3GB, I'm just concerned with the really high number. Like I said above, if that figure reads above 6GB, doesn't that mean I've run out of VRAM? and the effect of that would be my game crashing, becoming unresponsive etc
ah ok, cheers. Never quite understood what happens when you reach the VRAM ceiling.
What frames have you locked at?
I have most on high (few on medium) on my 670 (@1080p) pretty much no issues unless its raining and a big fight, or in wraith mode which seems the most problematic for me.
Is it not just like we seen with titanfall, where it is caching as much vram as your card has got?
I've got a 2500k at 4.5 and a 7950 3gb and can't seem to get 60 constant on any settings - latest drivers, any ideas? usually around 40 mark
Pretty much yes.
Definitely something not right there. I have pretty much the exact same setup and even at ultra it's pretty much a steady 60fps with drops into the late 40's early 50's in big battles or rain. I'm on 14.7 RC3 drivers iirc and gpu oc'd to 1070/1500. Have settled at high preset for no drops though.
Hmm, currently trying to decide if I should get this on the PS4 of the PC...
The PS4 is linked upto my 140" projector/better gamepad. PC on the other hand will have much better graphics.... choices choices...
So, my GTX 780 is going to struggle to run this at ultra settings at 1920x1080
