- 7 Sep 2012
- Lancashire, England
Mine is L420B864... Not sure if it's a decent chip or not as i'm running it stock for now. All I do know is the voltage hits 1.263v under load when it's boosting to 4.4GHz (voltage stayed the same when I tested auto OC to 4.6GHz).
Also, does anyone here know roughly what the IMC (memory controller) voltage should be at? Is it usually higher than the actual RAM voltage? My Asrock OC software shows DRAM as 1.500v and other software like Speccy don't show DRAM but instead show Memory Controller as 1.696v... Is this high?
