- 19 Feb 2007
- Sol
You have to think twice when you buy from overclockers uk.
I think that's a little unfair, OCUK can't control what goes on at the factory.
Will we be seeing you on the bench threads?
Roll up, Roll up![]()
I had bad experience with them in the past.![]()
Yes for sure, I'm not one for benching, but I'll give it a go. At the very least It will give me some guidance to show that my system is setup well.
No way.
Apart from the obvious that it is not in a brand new condition, you could even void your warranty by bending it yourself.
Absolutely this. You attempt to bend it back yourself, and you make a mistake and break something on the circuit board, then you've got yourself an expensive door stop.
I can't believe an OCUK employee suggested that to you. Poor form if true.
Hello there people.
Just seen the picture of the bent I/O backplate on the card. I am sorry to see it has arrived like that but being honest with you it must have arrived from the factory like that.
It is unfortunate that it is slightly bent but it only takes 2 seconds to bend it back. All of the 980's are brand new as well.
@Kaapstad - I really do not know where in the world you get your information from about voiding warranties but I deal with warranties day in day out and this would not cause an issue.
@Kelt - This is a piece of metal and no where near the circuit board and in all my years of computing I have never seen damage due to bending this.
If i was on the support phone I would have advised to bend it back too.
Anyway having checked the Unique ID of the card it has never been out of stock and is brand new, it is just unfortunate it arrived with a little defect on the I/O.
If you wish to RMA it we can do but your warranty would not be effected in any way shape or form on the one you received from bending that back.
Thanks
Bailey
Got my two!
Only got one in my PC at the moment, waiting for my Haswell-E parts to arrive then it's time to put them both in![]()
Just seen the price of the EVGA 980 SC. Blimey that price has skyrocketed! Considering I got mine for £470. It's now a whopping £530...
Did the pound fall into the fires of Mordor when I wasn't looking?
Just fitting that will straighten it. Seems a lot of hassle to RMA just for a quick tweak with some pliers. Seems to be an excuse to RMA as its a poor clocker tbh. I'm sure if it was a good clocker the bracket would have been a non issue...
Ref Design or X3 Ultra/X4?
Both reference design
Cheers Dan, are you getting any coil whine/problems, im now considering getting one of these cards.
Neil
I've been looking at these also. Haven't heard many having coil whine issues with 980's
The prices has gone up because People will be looking to SLI their EVGA SC and it is sort of a last buy. I'm not agreeing with the price and this is why I actually sold my EVGA SC and bought two non references cards when I saw EOL on them.
