- 27 Oct 2013
The OCUK reference card is the same as Gigabyte but £30 cheaper.
Exactly the same, except the packaging and possibly the warranty?
Both have 3 years warranty and do you really want to pay £30 for a box with Gigabyte on it...![]()
Having some performance issues. my 2x EVGA 980 SC's are not performing as well as they should.
For example my graphics score on the standard firestrike was around 19-20k. However my friend running 2x Galax 970's was surpassing my score. When I also deployed a heavy OC than him I almost broke 21k graphics score, he hit 26k with his 970's. Another friend with 2x 290's with an OC has an almost identical graphics score as well.
The OC I gave my card was +250 Core and +350 memory.
I'm guessing I have a bottleneck. My Mobo is a z97 gaming 5 and I have an I5 4670k at 4.4 ghz. I also found in my GPU Z that one card in the X16 slot, one is running at x8 but the other is at x4. Would this be causing a problem?
Could use some help here.
Could be Windows. Windows 8 score a lot more in FireStrike, than Windows 7.Any one able to give any extra insight into this?
Yea, it's stupid. My FireStrike score is damn low, only because of Windows 7.
http://www.3dmark.com/fs/2980490
Sounds weird your 2nd GPU run x4 though
Interesting, have you swapped to windows 8 your self?
And yeah I have no clue on that front, I even tried to manually set it to 8x/8x/0x but didn't change anything when I checked in GPU Z.
Just the difference between Windows 8 and 7 in FireStrike, unfortunately.
Sorry for the late reply, been out all day - no problems with coil whine etc, it's very quiet!
