same issue for me
1 fan now sometimes runs at 100% and the other turns off completely, i have to reboot to get it back to normal.
I moved from ATI because of problems only to hit a new one with Nvidia...sigh
Ok, so Min 30% and then you fix the rest of the fan curve, I'll tryBig thread on MSI forums and its not a fault of the sticker.
I run Min 30% on the fans and all seems fine for a week or two now.
Appreciate this is not the solution but if you don't want to do the return route then try it.
Its still silent at 30%
I think MSI will lose a lot of customers next round of cards.
Temperatures are a little toasty for me, hitting high 70's even after a short session. My (mATX) case is a little cramped, am I better exhausting more hot air or getting a side intake or something sorted?
No they wont because people get suckered into good deals and WOOOO MSI! Just look at how many times I warned them about the way they treated their customers and fan issues.
No excuses![]()
Sounds like you need to sort case airflow out, neither MSI for me goes over 65c during gaming
I touched the stuck fan and now everything's going fine, let's see how long it lasts.
so... asus strix or gigabyte g1 ?![]()
Pushed the Strix to 1516mhz stable without touching the volts. It went back to 1503 a couple of times in Crysis 3 for a brief time. I'm not sure whether the card was throttling down because it sat on 1516mhz for far too long. I think there's no point in further overclocking, I might go for another 5mhz to get a nice and round +180mhz;p
Didn't expect the card to reach such clocks without crashing even once. I only hope it won't conk out on me when least expected as I don't really want to put up with Asus's RMA (even if the retailer handles the entire process);p
