Well done on the order. It may be shipped sooner as mine was. Of course you are then at the whim of a dozy FedEx driver
Mine is 32gb Black / Black / Gold Accents. The gold is fine but maybe should have gone red. Not a big issue.
First full day as work-a-day phone yesterday and all was good. Battery life does seem quite a bit better than the '13 Moto X .. which easily lasted the day (6am to 11pm) and then some for me. Last night it was charged when I went to bed about 11pm and basically left with wifi still on it dropped to 95% by 6am. This is quite a bit better idling battery consumption than I've been used too. Of course as battery beds in it should get better in a few days. Everyone's milage may vary.
Although the new X is bigger it does not seem any heavier. The specs say it is slightly but certainly doesn't feel like a lump of lead in your pocket. Maybe the smaller battery has helped there. I'm still getting used to it but never thought I'd even consider a 5.2" phone. It is a little clumsier than the old model but not overly.
Bought a gel case which is quite compact and does afford some protection to what might be the vulnerable screen edges if it was say dropped. BUT it does spoil the feel of the phone and suspect half the time I'll not bother with it. It does give a little extra grip though.
Display is great though bright sun somewhat in short supply to see how it fairs in that.
Signal reception is better (for me). One site I work at has weak coverage and on average the old X used to report 20 to 30% of time there without signal and yesterday at same site with new Moto X it reports 6%. I will say with both phones I never actually catch either without signal there
As has been mention call quality is excellent - subject to the quality of the other persons phone/signal/prevailing wind.
The LuvTab Military Tempered glass screen protector off of amazon is rubbish. It's still on but not sticking at all around the edges
One review there (now
) says the same. I suspect it has to do with the shape of the glass. I prefer something to protect the glass from scratches but not sure this is going to be the answer. And yes, Gorilla glass does scratch. In my case I think it's fine grit/sand that finds it way into pocket and scratch really fine lines into the glass.
All told really liking the new Moto X. I think the only disappointment is Sky Go doesn't work
Evidently I will probably have to wait for the new unified Sky Go app currently in beta. Current app loads OK and is compatible with Moto X according to Play store but get a message the phone isn't supported when I try to log in. Otherwise all good
