I have a £15 off over £50 if its any good ?
That'll definitely help, thanks! My trust is configured
What is your budget?
Also probably better with a CX bike? Or whatever they are, hybrids are horrible.
no more than £100 if possible.
At £100 anything really aslong as it works.
Get something with 100mm of travel or stiff forks if you really want a mountain bike. I've seen some old rockhoppers etc go at £100, but no doubt you'll end up with some maintenance straight away. Wheel bearings, headset bearings etc.
Okay thanks. How much would I need to increase my budget by to get something decent which will last a long time and be reliable etc? Only using it to commute 20 mins each way a day.
edit: Sorry meant 5 mins each way a day (20 mins was walking time)
Get it bought (depending on how tall you are by the way, 20" frame)
http://www.pinkbike.com/buysell/1677545/
Originally a £400 bike, looks in good condition with shimano hardware. Wont hurt to sign up and ask if he will box and ship it, ive dealt with plenty on there that say local pick up but will sometimes post if you ask nicely.
