- 18 May 2010
- London
The Android Lollipop game is so much harder than flappy birds.
My max score is ..... 1!
Hard to say what my battery life is like so far but maybe it is a bit better.....
http://i.imgur.com/jqGiWmdh.png[IMG] [IMG]http://i.imgur.com/bDnR3kMh.png[IMG][/SPOILER][/QUOTE]
Do you turn your wifi off overnight? :confused:
Yup, I am asleep so no need to have a data connection during that time![]()
Enjoying most things so far. Only thing I'm not liking is that when using chrome the tabs are seperste applications. (If that makes sense?) Is there a way of turning that off?
Why anyone wouldn't use WUG for the Nexus is beyond me. Even those who aren't rooted. It literally does everything for you
WUG??
Problem with wifi at work. Cisco AP's.
Connects fine at home, but at work, keeps saving connected/saved over and over but never fully connects.
IPhones and other devices work fine.
Will cause an issue as means i can listen to music on my phne at work without using data allowance.
Oh wonderful. Seems to be a confirmed issue with Cisco Aps..
According to post 24, this issue only occurs with Factory image not OTA...
But they should theoretically be the same thing surely?
Seems I may need to go back to 4.4.4 connect to corporate network and wait forthe OTA after all....
I think i understand the problem, you need 4.4.4 to make the connection to the Cisco AP (as 5 has an issue) then the OTA update preserve the connection meaning that afterthe update you have 5 as well as connectivity to the AP.
