Finally gave in and ordered one to replace my Nexus 5.
Well done - you know it makes sense
No Mate it's still stuck in Shenzhen, China since the 11th awaiting clearance maybe the Orange accents on the phone are too much for customs over there!
It's apparently due to be delivered next Thurs though so I just have to keep my fingers crossed that it arrives by then or maybe earlier if I'm lucky.
How are you finding the phone?
Stoosh, is you Moto X any nearer?
I removed the glass screen protector as dust was starting to get between the the glass and the phone glass around the edges due to them not sticking down. Fitted the Skinomi Tech skin. Went on easily enough and has fitted very well. Quite smooth but there is a very slight hint of tackiness. Overall it's fairly good. Downside - you can feel an edge when you slide your finger off the edge. This is more noticable as you seem to do the former opening the lollipop style menu on the left edge. Bare you have the curved glass which gives the phone a nice feel. Would prefer a glass screen protector that fitted but the air gap all round the edges seems to be the norm. I think unless one that has a similar edge curve to the new Moto X is developed then the only glass one that will sit down properly will have to be slightly smaller than the whole screen.
I forgot to say that the iLLumiShield screen protectors arrived. Three in a packet. First one went on well ... until I realized it was on upside down
I then proceeded to get a finger print mark on the underside of the skin and ruin it. Second one fitted not so bad but having got it set down and air bubbles pushed out I removed the outer layer of protective cover and lifted the whole thing up after which a couple of dust specs got under and it'd not sit down properly again. This was in a 'moist' bathroom! That is when I fitted the Skinomi.
I'll see how the skinomi goes. Not really that keen. Something has marked the 'skin' already
Half tempted to use nothing and treat with Crystalusion. Used in the past and does help with fine scratching .... I think
Otherwise I'm really liking the the new Moto X. Motorola have made it pretty efficient regards battery drain. Quite a bit better than the old X. Even got used to the size
Doesn't feel so big now and old moto x feels small.
Being on Three I've always had the little '3' icon top left of the notification bar. Presume this is for peeps who forget what network they're on
Found by accident that if you go into settings-more-mobile networks and third item down 'show mobile network' and uncheck it and it's gone from notification bar YAY. I'm probably the only person who hasn't noticed this!
