I dropped my system from 1920x1200 to 1260x900 or whatever the next one down is thinking it would help. I barely noticed a difference!I've got a really old system, but I've gone from low all the way up to ultra settings and it seems to make no difference. It runs the same on all. Playable, but not smooth.
so i went back to FC4 & it ran like a dog as well, really bad & for the first time for me it was totally unplayable
I altered it & restarted & FC4 ran superbly. How this setting altered to 2GB I can't imagine
You running a 980 with a Q6600 Usher? What res are you playing at out of interest?
nVidia [COLOR="Red"]Avg: 26.100[/COLOR] [COLOR="red"]Min: 18[/COLOR] [COLOR="Red"]Max: 34[/COLOR]
Ultra Avg: 26.371 Min: 19 [COLOR="Lime"]Max: 75[/COLOR]
Very High Avg: 30.116 Min: 20 Max: 50
High Avg: 29.940 Min: 21 Max: 46
Medium Avg: 32.384 Min: 22 Max: 53
Low [COLOR="lime"]Avg: 35.058[/COLOR] [COLOR="Lime"]Min: 24[/COLOR] Max: 60
I found a fix on the net where you type msconfig & then select boot, advanced options -maximum memory & there I discovered it said just 2GBI altered it & restarted & FC4 ran superbly. How this setting altered to 2GB I can't imagine
I'm still amazed your 2007 spec Core 2 Duo even loads Chrome never mind the uplay app
So I did some benchmarks with Fraps. Its clearly CPU, RAM, or somthing else limited, and not graphics. The difference between everything on and everything off is negligable, to the extent I can't tell. Its all not very smooth.
Code:nVidia [COLOR="Red"]Avg: 26.100[/COLOR] [COLOR="red"]Min: 18[/COLOR] [COLOR="Red"]Max: 34[/COLOR] Ultra Avg: 26.371 Min: 19 [COLOR="Lime"]Max: 75[/COLOR] Very High Avg: 30.116 Min: 20 Max: 50 High Avg: 29.940 Min: 21 Max: 46 Medium Avg: 32.384 Min: 22 Max: 53 Low [COLOR="lime"]Avg: 35.058[/COLOR] [COLOR="Lime"]Min: 24[/COLOR] Max: 60
Going by this, I think I'm going to bosh it on Very High and leave it.
Going by my system spec and how badly it runs I would say it's not a problem with CPU, RAM or GPU. It's just poor programming.
I enjoyed FC1, skipped FC2, and bought both 3 and 4, personally I think 3 had a better story, at the moment, I like 4, the helicopter is a nice addition, but as someone said above, it's more of the same, go here, kill him, go here, find treasure, kill this animal, repeat
Jay794 (it's more of the same, go here, kill him, go here, find treasure, kill this animal, repeat) It is a bit like real life do you not think. (Wake up fight your way to work, Half kill yourself trying to do the job or some one else, then fight your way back home and then back to bed again. Repeat.![]()
PC Patch 1.5.0 - Week of December 8th, 2014
PC Patch 1.5.0 will be available next week for download.
Patch Notes:
Added 21:9 aspect ratio support
Added Russian text and subtitles to worldwide game version
Fixed an issue with aim assist
Fixed an issue with grappling if aim button was remapped on another key
Fixed an issue with mouse input
Fixed an issue with movement key binding on mouse buttons
Fixed an issue with Uplay invites in Steam version
Fixed various Controls issues
Fixed various Graphic issues
Fixed various IGE issues
Fixed various Session Browser issues
Fixed various UI issues
NVIDIA graphics preset was removed
Reduced performance drop impact during streaming
