So what happens when Sony shuts down the servers for their older consoles?
You continue to play the up to date console you have
You continue to play the up to date console you have![]()
https://mega.co.nz/#!2pFVFbKY!BN_AMoeUrtYBuSJL5cLaDNlUTL1yFdXAeau3617hWgk
amazing quality b roll footage of the Order.
Currently a 500 gb stock. But just about to upgrade to a 2 tb as I can get a Samsung 2 tb in a caddy, remove the drive from the caddy and use the drive in the ps4 and use the 500 gb in the spare caddy..
500 gb isn't big enough I feel, some will argue it is. I don't think it is.
No doubt youve been asked this question but mind telling me the model of the Samsung you put in? I know people seem to use Seagate but I wouldnt touch them myself while WD have a nasty habit of soldering their HDD connections - Samsung seems a safe purchase and Im getting to the point where 500Gb isnt enough too
ps3ud0![]()
It's a ST2000LM003.
I'm pretty sure Samsung and Seagate are the same company now though...
I still play Super Nintendo games on occasion, how do we do that in 25 years time on digital download systems?
It's not like I can put my digital games onto a replacement console if mine breaks either as I can't transfer the licences without PSN/XBL/Steam being active.
It's a ST2000LM003.
Ta dudeIt's a ST2000LM003.
Glad you posted might look into that thenSame here, eurogamer had df article on this, using a Samsung 2 tb external drive which they removed from the caddy and it was in fact a Seagate drive inside the caddy..
Yeah I should have bought one in my last round of portable external HDD buying but ended up with 2x2Tb WD Ultras instead. Im not that near to the 500Gb limit but know its never going to be a good time to swap overYou can get that external for less than £70 which is cheaper than buying the drive separate. only downside is y warranty claims might be void if there are sings of opening on the enclosure.
Still a nice saving though and you get a caddy for the 500gb drive...
Like you Im on VM but not had any real issues other than Destiny contacting servers message a few times in the last week. Been pretty solid but messages are a PSN issue for sure (it seems to happen when US wakes up), sometimes I have random NAT issues in party chat but a quick leave/rejoin fixes that usually - friends list has been bulletproof since they fixed thatHad anybody had issues with psn this week? Sometimes I can't join parties, friends and messages won't load. I'm getting errors all the time in destiny. I'm trying to work out if it's issues with psn or my Internet.
I've had issues all week, I can't even get into destiny anymore (been fine since release) with all multitude of animal errors and can't connect to server.
Psn is dropping out a lot also.
I'm supposed to be in a raid tonight but it might not happen.
I spent all night last night opening ports etc to no avail.
Its honestly to the point now where I can't use the ps4 for online which is a shame as I've had no issues since launch.
With BT by the way.
