- 24 Mar 2004
- kintyre
thanks again mate, this is my first water cooling build and im still a bit clueless when ordering items, even though i have done quite a bit of research.
FYI: 3-pin Aquabus are 3-pin male-to-male fan cables
4-pin Aquabus are 4-pin PWM male-to-male fan cables.
Extensions are just male-to-female of the same.
That would work fine. The flow port isn't an Aquabus port though. As far as I'm aware, it's a modified fan header. When I say "modified" I think all they've done is label it in the software as a flow sensor and allow you to specify how many impulses per litre it generates. I think you can attach the "Alarm" port of the flow sensors to the flow port to get an impulses per litre, fan-style connection...but don't quote me on it without confirming that I'm not just making that up!
Yes, these cables are just three or four pin-to-pin connections. Same as either 4-pin (PWM) cables or 3-pin fan cables. Male-to-male for making connections. Male-to-female for extensions. The following do exist but are not in stock:
- 70cm Aquabus Cable 4pin
- Aquabus Y-Cable 4pin
You can use the following from stock:
You MIGHT be able to use this Akasa PWM splitter as a Y-splitter but it depends if all 4 pins are connected. Cannot tell from the pic. They SHOULDN'T all be connected as the tacho cable shouldn't be split for fan use but to use it as an aquabus splitter, all four would need to be connected to both trailing sockets.
Hope that helps.
Gareth
