A 2TB 5200rpm 2.5" drive is almost as fast as a 1TB 7200rpm 2.5" due to the increased platter size. You would notice little difference in the real world.
Your using stupid examples.
3.5" drives are very cheap for large capacities therefore you should be comparing 7200rpm 3TB 3.5" drive with a 5400rpm 2TB 2.5" drive. The 3.5" drive has larger platters and spins faster.
the difference between the two would be HUGE, both the above should be similar costs I imagine.
but this is what you really should be looking at
http://www.overclockers.co.uk/showproduct.php?prodid=HD-292-SE&groupid=701&catid=14&subcat=1894
7200RPM hybrid drive, 1TB and only £63
you have 8gb cache but with a 7200rpm drive instead of the 5400rpm in the smaller hybrid drives, it's also cheaper than 2.5" drives, so more speed and costs less.
But you have to have a horrid thing stuck on your PS4 to use it.
What I was saying is a 2TB 2.5" drive is a better and neater option. You can get one for about £70 if you buy the usb drive and take it out. It fits nicely in the PS4 without any additional bulky adapters and offers decent performance similar to a 1TB 7200rpm drive with plenty of storage.
I think 2TB is plenty of storage at the moment for the PS4 even I have not filled it up and have nearly all the games launched so far.
If you grab a Seagate Expansion 2TB USB 3.0 Portable Hard Drive model STBX2000401 you can remove the 2TB drive from the enclosure and fit it into your PS4. You can then use the enclosure for your 500GB drive.
It is cheaper buying the drive as a USB external than the bare drive alone.
its actually not a bad enclose either, mine came with a samsung drive inside which i'm sure they all are? Think it was £59.99 if i remember correctlyPersonally I would just stick the biggest and cheapest 2.5" drive in and not worry over the small speed increases some drives bring. In the real world a faster drive makes little noticeable difference.
I had an SSD in mine for a while and even that was nothing to get excited about tbh.
All the tests show hybrid drives are the best all rounders. You just have your feelings to go on but the numbers are out there in spreadsheets online. Unless you timed all your drives.
Like I say I never see my console so I don't care if the add on looks hideous. To me a 3.5" hybrid drive looks perfect. You get the cache, you get large platter sizes, you get 7200rpm. They are also cheap compared to 2.5" hybrids.
I was saving up for an SSD, but this looks like a much better option.
