- 19 Feb 2007
- London
So what's everyone getting for clocks ? so far I have 1120/1500 game and bench stable
thats pretty niceWell so far without a voltage increase I've managed to get a solid 1150/1600![]()
Is it normal to be able to hear the water constantly sort of splooshing inside the loop of the AIO ?
*EDIT*
It sounds like an air bubble, Any way to remedy this ?
*2nd EDIT*
Seems to be gone, Very odd![]()
I know it's different for everyone, but how much has the OC's added to your temps? My GPU throttles if I don't have the front of my PC off (it's my case, not the card).
Nice Virus, really does seem they binned the nice chips when they were charging £1100+![]()
Why is there not a list like in most other owners threads on the front page listing owners ???
I quite like that fat4l !
How you finding the spectra fans? Have some myself, only the plain black ones
Shame they don't push a little more through a rad. Mine are quite thick though.
Edit:
May I ask what quick connects they are?
MSI 295X2, Sapphire OC bios, 1030/1300MHz
working on it now brother!Crank that shiznitz up dude, So far on air I've managed 1150/1600 but run 1100/1500 24/7 clocks, I think I got a good one![]()
its QD4 Female Quick Disconnect No-Spill Coupling, Compression for 13mm x 19mm (1/2in x 3/4in) *Black* QD4-FS13X19-BK and QD4 Male Quick Disconnect No-Spill Coupling, Compression for 13mm x 19mm (1/2in x 3/4in) *Black* QD4-MS13X19-BK.
its a shame ocuk dont do them(atleast female one) but u can buy them from one uk/germany retailer.
check http://forums.overclockers.co.uk/showthread.php?t=18643190
the fans are spectre PRO not just spectre and they push a bit more air than spectre and have higher static pressure. fpi of mora3 is not that high and push-pull condiguration helpsnot sure uf they would be able to push air through Alphacool NexXxoS Monsta rads tho..
