Well you either want the faster card or you don't, as you order is not shipped you can change it at any time.
But the 970 card which won all those reviews and has being raved about for months, is still that same excellent card, nothing has changed in the way it has performed since day one. So you only need to upgrade if you now feel a 970 is not powerful enough for you.![]()
Nope. The main reason i went for the 970 was 4gb of memory on a 256bit bus with the cache and the ROPS it was advertised as having. Not 3.5gb of memory with .5gb of memory that causes stuttering when used and less specification than it was advertised by NVIDIA as having. And some 'average FPS' fob off.
The 980 is as described, the 970 i ordered is not. Also, the 970 was really more than i wanted to spend. I was tempted into it by your tinkering and the 4gb of full speed memory i was informed of. I cannot afford a 980. Nor can i run an AMD space heater in my aircooled SFF pc. The only route for me in this case is down to a 960 which is even less suitable for what i want
I'm quite aware that futureproofing does not exist, but i had in mind performance at certain settings over time. Only to find out that the £300 card i ordered probably isn't as good for that as i was led to believe it was by false advertising.
£300 clearly isn't as large a chunk of the available funds for other people as it is for me - seeing the specs some people talk about. It's a LOT of money for me. Please don't mistake the tone of my posts for someone who isn't feeling negative about their purchase, because i am. I am apocalyptically furious mixed with a lot of disappointment and feeling lied to by NVIDIA.
