As an aside Matt, do you think my PSU would handle another?
It won't. These cards can draw about 600-700W.
Dear God, all this card buying by Matt makes me want to buy another 295x2 NOW!!!!!![]()
edit - And if not, is TriFire a decent upgrade for high-resolutions? Am unsure of the gains tbh
http://www.anandtech.com/bench/product/1187
Total system is 686w. I'll wait for Matt to answer, thanks.
(although you're probably right Shiari)
Matt, just in case it doesn't then how does TriFire scale at high resolutions at the mo?
edit - Dear God, I *never* realised just HOW good 295x2 Crossfire scaling is at 4kGodlike indeed
Definitely watching to see how you get on with these Matt I always had a suspicion I would add a second 295x2 when I got mine so went with a 1600w P2 when I got the first.
Matt are you putting the cards in your 540 Air?
I'm thinking of getting the case if I do get a 295X2. Just wondering how the card copes in it.
I'd offer to buy but I'm a bit far away to collect itI was going to Tom, but you'd have to put the rad in the rear. If you put it in the front, there won't be room to run push pull and the fact i have two 295x2's. I decided i needed a bigger case, so I'm about to to throw the Carbide 540 away. I was going to sell it, but not sure i can be bothered.
I now have a 750D which has lots of room so seems much better suited to the 295x2.
If you run one 295x2 and have the rad fan in the top rear, the 540 will be excellent for the 295x2.
The 750D is actually the other case I was looking at. It looks much nicer, but I do like the two compartments that the 540 has.
TriFire scales better than QuadFire at 4K but that's to be expected at any res really.:
Let me know how you get on.
I bought a couple of these today to replace the stock fan and run push pull. The idea is to get things as silent as possible.
I'm missing the reference cooler though, i won't lie.![]()
The 540 works really well, the only problem is it attracted a lot of dust i found, even with decent filters. But i guess that happens to every case really.
Both are nice cases, i like corsair cases in general i think. This will be the third one I've owned in a row and all had windows.
