I`ve been asked for more info, which I`ve sent.
There is a problem, and I think they must know there's a problem.
I wonder if they'll deal with it, or hope it goes away ?
"sweep it under the carpet and hope no one complains"
they can fix it easily,just scrap the cheap tlc nand and shove some mlc nand in their,but they wont because Samsung manufacture their own cheap tlc nand
I bet they run into the same issues with the new 850 evo's further down the line
if its a controller bug its taking them an awefully longtime to fix it,and no problems with the pro drives which so happens to be using mlc nand
I can guarantee you I won't be going away. If this isn't fixed I will want a refund or a replacement, not including TLC NAND.
Looks like next time I will be buying a MX100. The firmware update fixed my issue but then it seems to have slowed down massively again, trying disk refresh to see how that does.
I ran the restoration tool for a second time but it's slowly degrading yet again.
If you reinstall it you can run it again. It won't reflash the firmware, just runs the perf restoration part.
On that note, why don't they just let you run it when you want?
In theory if the issue is fixed it only needs to run once. It uses up write cycles so they don't want you repeatadly running it for no reason wearing out your drive unnecessarily. As we know though it's not fixed so we have to go back to re-writing the data to temporarily mask the issue.On that note, why don't they just let you run it when you want?
No just uninstall it, then install it again. Try a few reboots aswell if it's not letting you run it.Is there a registry hack I need to do ?
Is this ok?
Uninstall
Reboot
Install
Reboot
Run it
IIRC I didn't need a reboot, just uninstalled, installed, ran it again. It took about 20 mins for it to run which was the same amount of time it took the first time and performance was restored, for now at least.
Strange, it works here and I can see it's worked for people on OCN aswell.I've tried running this again and following those steps by uninstalling, reboot, then reinstalling etc. But it always says complete and I can't run it again.
