Rotate the screen to enable the menu! Can't believe it was so simple!!
You sir, are an absolute star!!
Mame, have another star, or a pint, or whatever your fave tipple is! Thank you!!
Barclays banking app no longer works. Balls. Just me, or anyone else notice.
Not working for me either (Mybarclaycard app.) Splash screen opens and closes after half a second or so. Uninstalled and reinstalled, made no difference. A couple of reviewers on the Play Store have said the same.
For me so far:
The good: phone feels faster and smoother, though not sure if it actually is.
The ok: Battery life seems a little less, probably around 4h30 screen on time instead of the ~5 before.
The bad:
The Barclays app doesn't work.
Cerberus always takes a photo after one failed attempt to unlock the phone even if the app is set to more (to be fair, the app does say it's a necessary workaround. Still annoying though.)
Can't turn off the "power saver mode" notification on the lock screen without turning off lock screen notifications completely. Seriously, do I need to know that's turned on every time I pick up the phone??
The worst thing of all though....toggling mobile data from third party apps isn't supported. So that's half my Tasker profiles broken then. Gee, thanks Google!
None of them major issues, just annoying
