TGM are currently painting another rocker cover which I should have fitted in a few weeks.
Not sure if the front set up is of similar design on the FK2.What's this part called and how easy is it to replace?
Hi guys, I've posted regarding this before, but had no luck fixing it, included a video this time as well.
I have a 2009 Honda Civic FK2. When turning the wheel there is a loud clunk coming from just underneath the driver side. There is also light clunking when moving slowly and turning at low speeds, as well as when going over speed bumps.
The clunking doesn't happen all the time but i've noticed it getting worse lately.
Any ideas? I've taken it to Honda and another private garage, and neither could see anything wrong from a physical inspection.
Lings
Already checked and it's not clear.
I can see the part number for the 'cooling plate' but I believe this is a mild steel bar that bolts down to the cooling plate, spreading the load so the plastic doesn't break.
I think I'm going to try and remove it, sand it down and re-paint. I'll probably replace the bolts too with some cheap ones from tegiwa.
Have you ever had the subframe checked/bushes greased? I'd start there if there are no worn components
Have you noticed any changes in the steering? If so it could be tie rods, failing that ball joints.
First honda with good brakes in standard![]()
What's wrong with the DC5 or FD2? Fantastic brakes as standard![]()
