Do the Strix sag?
No. The backplate and brace does an excellent job. It should be noted that the shroud flexes a little once its facing down in your case.
Do the Strix sag?
Been reading through this thread tonight about creating your own tweaked bios.
http://www.overclock.net/t/1517316/...d-980-firmware-zosons-h2o-and-air-custom-bios
I dare say I'll give it a go knowing me.
Some people are getting some amazing overclocks with the G1 in this thread. Glad I have gone for this card now.
Looking forward to having a play with it!
Any idea when the "full fat" maxwells will be released? I'm planning on a new build in the next few months and will have the classic do I buy now or wait a few more months syndrome
Reduced the power limit to 270000 instead of 290000 last night and managed to get 2039 on Heaven 4. Core seems to be topping out around 1630
Water block should arrive today so will have a go tonight and see what happens. Will probably remove the back plate too as the SOC has voltage reading points for GPU and memory which are covered by the back plate![]()
Would you be so kind as to upload your bios? Another interesting tit bit I read last night was, you need to put your both temp target and max temp target at 91C. It will never reach that high but it should give an extra boost to to clocks if they reach a lower target threshhold
Anyone running two G1's?
Already have one and likely picking up a second tomorrow. I have decent airflow in the case.
I came from two G1 970s to two 980 SOCs and was surprised by the difference in heat, the top card was hitting 79°. A side fan has sorted it though.
I'm quite happy with that. A year of use justifies the purchase, and then it's hand-me-down to the media server with my 980 and gaming on a new 980ti!Looks like it's delayed until next year.
http://www.kpopstarz.com/articles/1...ease-date-nvidia-hike-price-graphics-card.htm
Cheers James
Yep, the SOC's are much hotter, if anything they can be up to 20C hotter than the G1's. I don't have the luxury of a side fan, as it's an Air 540 window
I did want the G1s initially as I found the 970s excellent, but the extra £120 quid was too much for me.
I've got a 540r too, removed the window and replaced with a panel made from Modders Mesh, fitted straight in, even used the tabs to hold it back in place.
Not really a window man myself...reminds me too much of misspent weekends in Amsterdam.![]()
