If it was the same driver you should report it.
I've reported it to OcUK, if that's what you mean. I think they need to be having a word with their DPD Account Manager.
Box has damage to the Corner. I've not opened it at all to check the Card out.
Reason for this, the SOC Card before this had the same Damage to the Box and had ripped the Anti-static bag it was in. That Card had heat problems (even more so than a good Card).
I don't want to risk it nor have to send it back in a couple of Days. I'm just after a working machine now, not is it okay or not.
Good call, I wouldn't be put off with the 980 GTX because of this though. It's the driver who's most likely doing it, probably throwing it in the back of the van and allowing stuff to sit on it.
Oh a more humorous note, the driver probably has an AMD card
heh![]()
I've just sent a webnote to DPD direct.
This is ridiculous, the cards are protected inside, scuffs and damage to corners can easily happen in transit, might not mean it has been dropped. At least show us a picture. Either way you should try the card as it may be an amazing clocker, run cool and have 0 coil whine.
It's a waste of your time, and OCUKs if you return purely because the outer box has a little dint/bash. Woopdy doo!
It's a box, unless you have a glass cabinet wanting to show off 980's in some sort of Museum, most people would just try it and see how it is firstly. If the card is in FULL working order, nothing wrong with it. I cannot see how its justifiable to waste time because of external damage to a box.
hope it is a monster and clocks well for you.You are quite right. And after some time to reflect, I will test the Card.
Mine came with a damaged I/O plate, but it overclocks like a beast so I decided to keep it.
Had exactly that same issue with my G1. Something dodgy going on with Gigabyte Quality Control recently.
Did you keep a hold of it, out of interest?
