*** The Official Xbox One Thread ***
Nope. It's been sat I'm the same position for a few weeks. My controller won't connect to the console and it won't take charge from it either.
Assume you've tried disconnecting it from the mains, not just turning on/off at the console. I had a similar problem this week and I disconnected it for a few minutes and then it worked, actually have that issue fairly often.
So I noticed the HDD was getting pretty full in my XB1 and decided to delete the expired BF: Hardline demo... but I can't! I can uninstall it but it remains on the HDD with my only option to install it again :confused:
This is 10GB I'd really like to get back if I can!
If I'm correct, it's in effect in the "Recycle Bin". The Xbone will reclaim the space when it needs it. You're not supposed to worry about space this gen. :D
Well the first one lasted a month and this one I've had over a year but it's hardly been used in that time.
Hmm odd. If they were both in relatively quick succession I would've suggested possibly a problem with the socket its plugged into, but alas, no.
Did anyone try the screen shot, I'm impressed, with Kinect voice and its 100% uncompressed full res and .png files.
Seeing now why it took so much longer to bring out.
I have just bought an xbox one and love it. However after Easter I will be back at uni for exams and I only have a PC screen for my room (no TV) - is there a way I can split sound and image from an xbox one i.e. image goes through HDMI and I get some kind of line-in sound output?
Can you use the optical out?
Or PC -> XB1 HDMI in -> monitor.
