- 6 Jan 2013
- Rollergirl
Heaven handles a memory oc better than firestrike, and firestrike handles core oc better.
Doesnt matter. I figured it out what was causing it. Whenever I have shadowplay enabled its causing this 3005 mhz lock. Disabled it, restart, fixed. Must be some kind of shadowplay bug or something else is causing shadowplay to react like that?
Anyone else who uses shadowplay get any issues similar to mine? Could someone try shadowplay enabled and see if it affects them?
Any body got an idea where I can get a modded bios for 980GTX SC
being held back by voltage and vrel at times.
any help appreciated guys.
I would have a Gigabyte if it was £50 cheaper, I will have a look at the Evga
I bought one last week, but it was £479 on "This Week Only" and the first one I bought last month for £469 and it came with a free keyboard!
Great cards, but £509 is a heavy hit.
So my KFA2 SOC has gone back and I have a refund [crappy knackered fan]. I want another 980 but the prices have all gone up, which one should I go for?. anyone got the Palit Super Jetstream?
Dude, there was 2 980 G1 in Clearance yesterday£369.00, keep you eye on the clearance section
I got a EVGA 980 SSC for £370.79 delivered. 5 yrs warranty after I registered. Bargin.
Guess who snapped them up at £379 each for SLI![]()
Nice buy! Are you happy?My EVGA 980 seems to have an issue with resuming from sleep, and if the monitor goes to sleep I need to reseat the DP cable to get my display back.
I'm also getting some NVKDLM errors (or whatever) every now and then causing me to reboot. I'm running a 100mhz OC on the core with no voltage increase, is this likely to cause it?
Dirty rotten ScoundrelNice buy! Are you happy?
Wonder why they were sent back as apart from the box being a bit dusty they are fine no sign of use on the fans or anything.
