- 22 Jul 2012
- London
Not sure that's gonna work, Smrtka. Not unless the particular 300 series card is a straight rebrand of a 290/x.
I doubt they will drop much lower than they are, and will eventually just become unavailable as the rebrands and new cards take over If thats your plan might as well buy now, I cant see a 380 or what ever the rebrand is being cheaper than a 290x now.well in that case I will wait until the 290x drops mega low
Already pretty low.
I sold a 290 for £130 last month.
Superb value to be had in getting a 290 Crossfire (or even tri-fire) setup, assuming your PSU can hack it.
What would I get for my 295x2/290x ref?
£600?
What are 2nd hand 295x2 + 290x's going for
£600?
I've probably already lost about £50 on the one I bought from Matt, not even selling for £420 now in the MM.
Yeah, I think with new tech on it's way and them only having 4gb is the issue. Not forgetting about drivers too. If they were proper 8gb then they would have held value a lot better.
for 1440 thay will be maxing games out for a long time to come and are perfect that use, the only real problem with 4gb memory is if you go to 4k monitor, but you need a lot more horse power for 4k gaming.
the one on the MM for £420 is struggling to sell because if you look in his posting history he mentioned in a few posts he was getting artefacts.
also the 295 is just two 290's and you can get 290's for £140 and i would always go dual card's over dual gpu card
You would get one set with your purchase. But you will need another set of 4 if you want push+pull
