write speeds are terrible in either direction: ~ 15MB/s
I am on powerline connection, but I would still expect more than that
Hiya what would be the minimum SSD size to install expen??
if you're using a parity raid option then yes it will be slower as it has to write multiple bits at the same time, and it will be slowed down by the slowest drive in the system in that parity group... If you're not using parity then it is likely a network issue.
What are the powerline adaptors rated at?
when I updated to update 4 (from main) I download the update and then manual install: browsed to the file and hit 'ok'. Didn't change any boot image.
I went from 5.1 straight to 5.1 update 4 with no issues
Do you mean you downloaded the .pat file seperately rather than update via control panel?
