Your RS is looking awesome there Mucky Pup
Is the KMS Thunderstorm the side exit system they do? had an RS go past me with one of those fitted and it sounded VERY loud! I spotted that the front section of pipe on the Mongoose Section 59 is the same as the one they use for their more 'polite' systems, so in theory could upgrade my Mongoose to one of those but Gary soon talked me out of it. With the regular Mongoose they sound nice and subtle till you put your foot down, but running a decat can introduce horrendous droning right at motorway cruising speeds
I spent a fair amount of time trying to find some fresh ideas for tailpipe designs taken from the bike world where tail pipes are used to give much more visual impact. Idea would be to then graft a suitable end onto a mongoose tailpipe outlet. Sadly the best I could find was on an Akrapovic motoGP type system and would have been either way too expensive or completely unobtainable. Keeping plan B under my hat for now
With the wheels seen on the mk3 ST press cars they're often built to specific specs while they make final decisions on styling combinations, supply constraints and so on. Also the content of spec packs often varies between different markets.
Your RS is looking awesome there Mucky Pup![]()
It's not a side exit, the Thunderstorm has 5.5" tips though. Looks ridiculous in my opinion but you can ask KMS to make them smaller (I am running 4.5"). They also do the Section 18 which "Poppy" is running (as well as Syvecs).
I thought black was worst you could get to keep clean? know after having a black Puma I gave up on that colour. It's look great after a wash but any rain etc left it covered in filthy dust spotsThanks, it's a nightmare to keep clean compared to my black ST though![]()
On the way to a RS breakfast meet and hit a pothole, looks like I need at least 1 new wheel and tyre, possibly two. Just hoping the suspension etc isn't damaged.
It damaged at least two other RS owners cars too![]()
That's got to be some kind of joke... tell me it is![]()
Have you reported it to the council yet and sought some compensation?
Good luck with that!
You need photo evidence I believe in order to claim of council. They will try to wriggle out of it though.
The thread has some good tips if you flick through the pages.
Be careful with EO, make sure the paint is good. I own one myself and I have found a previous repair that I failed to spot when viewing as its only really visible at dusk or out of direct sunlight, I'm now paying to get it put right as it bugs me.
Generally;
Knocking (nackered bushes - oil filled)
Wheel wobble (wheels buckle easily)
Rust where rear bumper meets arch
High pitched noise from engine (oil diaphragm - Google it)
