Hi all,
Really sorry if this has been addressed earlier, I tried a search, promise.
I have an MSI 295x2 and a gigabyte 290x trifire. Been playing GTAV using latest drivers.
Problem I have is, the 295 will suddenly drop to 300mhz 2D idle clocks then back up again, causing massive FPS spikes obviously. Memory speeds stay the same. With a bit of monitoring, I think this is happening when one of the 2 internal cards hits over 70 degrees.
Interestingly, the 290 is much warmer but keeps its 3D clocks.
Is there a way to prevent this?
Thanks.
EDIT: just confirmed it with Heaven. The moment the card hits 72 or so, it immediately drops to 2D clocks until it goes to less than 70 and goes back up again.
I should add the the 295x2 is set to 1040 GPU speed to match the 290x, with no increase in voltage or power limit percentage, because it has always been stable as such. Perhaps that's the mistake? Not sure if I can somehow manually control its pump speeds or set a curve like with fan-cooled GPUs.
You are indeed right sir, and airflow will SUCK currently because I'm messy.
Solved it for now by keeping the case side open.
Any recommendations for a good case for this setup![]()
I can field this one, the 295x2's vrms are throttling. Show us a picture of inside your case, we're going to need to improve your airflow.
I'm back in the club.
I would be interested to see how a 295X2 + 290X + 290P run in quadfire.![]()
I don't have any 290P's left unfortunately.![]()
Sell me a 290x Matt?![]()
I've only got 8GB versions and as they were provided for me, i can't sell them. Not that i would anyway, the extra memory comes in handy at 4k.
It was worth a try
Please tell me you had something underneath the card in the photo? and that it wasn't laying directly on those paving slabs![]()
It was, i was careful though.
It's yet to see any use at all, had it a few days now. Will give it a test on the weekend and see how it clocks.
It's going to live an easy life mostly, apart from the odd benching run.
