They make a good point about consoles in that interview as well, something people need to remember when getting upset about these things.
"If the consoles are not involved there is no Witcher 3 as it is," answers Marcin Iwinski, definitively. "We can lay it out that simply. We just cannot afford it, because consoles allow us to go higher in terms of the possible or achievable sales; have a higher budget for the game, and invest it all into developing this huge, gigantic world.
"Developing only for the PC: yes, probably we could get more [in terms of graphics] as there would be nothing else - they would be so focused, like if we would develop only on Xbox One or PlayStation 4. But then we cannot afford such a game."
Should I be able to run this 60fps witn most things max on a 4670k 290 16gb
(1080p)Is there a way to monitor fps in-game with SweetFX running? I'm noticing some annoying stutters and these don't feel like typical framerate drops. I might be wrong though, as even dropping from 60 to 55 can cause stuttering so I need to check it. I've set maximum pre-rendered frames to 1 in the control panel but that doesn't seem to have helped much.
Should've checked that in the first place
Apparently, Afterburner's OSD works with SweetFX so I could check framerates. In the first area, I'm mostly getting 60fps with occasional drops to 55-50 but without significant stuttering. I've maxed everything except shadows and grass density (both on high, practically no difference and less of a framerate hit) and used SweetFX. Makes the game look a lot better. I've also disabled some post fx (sharpening and chromatic aberration). I kept foliage visibility range on ultra, I hope I can keep it at that as it looks noticeably better than high.
And maybe do something about the vegetation
No, you should get a fairly consistent 50 with a few select options decreased though.Should I be able to run this 60fps witn most things max on a 4670k 290 16gb
Exactly, people were comparing it to GTA V and I just thought to myself, where is the merit in comparing a game that had a $265 million budget to one that had $40 million. Frankly it's awesome what they have achieved.
Just hit level 10 on arriving at Novigrad. Death march is definitely the most fun, even the bloody drowners catch me out now and again![]()
how are you guys levelling so fast lol. I just lost in the world and forget all about questing and stuff. I quite happily go on an explore for hours, hence the reason I'm still on level 2 hehe.
Sun and Stars is the best perk I've applied so far, really helps not going through my food.
anyone else attempting to run this with crossfire and getting flickering textures on the mountains and distant details? I'm guessing just a crossfire issue as AMD can't be arsed to do much for it's users at the moment.
Yeah, I've got this problem too. Using 2x R9 290.
Without crossfire enabled, the flickering disappears completely. Turning off crossfire actually results in me getting better FPS too.
I'll hold off playing the game until a new stable driver comes out.
What FPS are you getting with just the one enabled?
I just reached Oxenfurt. It looks quite nice, but again, there aren't any characters!.. I just combed every inch, and found nobody with anything to say other than the one I went there for(to do with a quest). The only quests are done through the notice board.
I miss vizima the where there were 2 inns, both with characters to talk to, and plenty of NPCs around town you could talk to any time, with various tasks and quests to do.
Touch wood not a single crash for me yet. I felt the FPS drop by 10 or so after a good 5+ hour gaming session, maybe a memory leak? Simply restarted my PC and the fps climbed again.
