Its kind of free but kind of not free as far as I can tell.
Right now I have 2 laptops and 1 desktop running Win 8.1. They are all eligible for upgrade to Win 10 free on July 29th. My understanding is that the Win 10 upgrade will grant you a free copy of the O/S that's good for 'the lifetime of the machine'. So in the case of my laptops that's probably fine as I doubt I would ever be changing the MOBO or other components sufficiently to make them 'a new machine'. So the installed win 10 would likely last beyond the first (free upgrade period). Its alway possible that a laptop component would go 'pop' and a new drive or something would be needed and in that instance I don't know what happens to the Win 10 upgrade.
My major concern is my desktop. I change parts in that fairly regularly. I have 5 HDD and an SSD for a start, I upgrade them quite a lot, I have changed CPU and MOBO in the lifetime of this machine. I am seriously considering a change to Skylake when it arrives so thats potentially a new MOBO, CPU, memory right there.
My question is if I go ahead in July and install Win 10 either as an upgrade or a clean install from media (if thats possible) what happens if I opt to move to Skylake in say November odd? New MOBO, CPU etc so I assume that's the lifetime of this machine over, so does this mean I couldn't even reinstall Win 8.1 then upgrade to Win 10 again because I have already had my free upgrade once? What happens if I wait to change my MOBO until the win 10 'free' period is past? Do I have to buy a new copy?
This same sort of query comes up every time MS announce a new version of Windows with slightly different activation procedures, and it's never really been an issue. I highly doubt it'll become one now.
I tried windows 10 a few months back and I used the same X-Fi drivers and apps that I used for win7. I never had any probs using the win7 drivers and they are old too.
Yep, it's always been what ever the original license is, is what the upgrade license becomes. And from windows 8, OEM = retail with no restrictions on change of hardware or changing it from one pc to another.
Where in windows 7 and before they classed OEM as tied to the mobo. Although it was never really enforced.
Settings hold on reboots? This was where my Prelude fell over for Windows 8/8.1. As well as many other X-Fi owners.
My drivers were from 2011.
so did I read this right when I want too fresh install I can just use the win7 key I have now ?
I'm not sure if this is only for Windows Insiders like myself at the moment, but if you get this:
Then i recommend you reserve a copy. Because it will download Win 10 over the next few weeks, then download the remaining parts/RTM updates just before release. So it's ready to install on release day.
This way you'll get the update sooner because i imagine servers/download speeds will be crippled on the release week from all the downloads.
How does this work with OEM devices?
I have a Dell XPS 13 and it has a lot of useful software installed and required drivers as standard.
What happens when you do a recovery (presumably this will revert it back to 8.1 as I doubt it will touch the recovery partition) will you lose the ability to get Windows 10 after July 2016?
Just seen this in Windows Update. Hopefully it'll pre download. Was wondering though, will I need to back anything up ?
I notice it says in the upgrade info icon link: Windows media center will be uninstalled during the upgrade. It isn't available in windows 10.
NiceIs there anything to replace it from MS?
My preference has always been and always will be a clean install and that is what I want to do this time
