Windows 10
seems odd given all the bother tehre was with windows 8 keys not allowing fresh installs of 8.1
If you upgraded from 8 to 8.1 you didn't get a new key.
The fact the clean install process for 8.1 was a bit broken is unrelated. MS have confirmed this isn't the case for 10 as you can clean install straight to 10.
well fingers crossed they learned from how things went with 8.1. i dont know where you found the info but thanks. it had been bugging me. :)
As with everything MS its a case if piecing together all the random bits of information they have trickled out through all sorts of channels.
Sigh.
Once you understand how OEM keys are managed and how sealed devices work with keys (laptops and tablets) it makes perfect sense.
For every pre installed device with Windows on it there is now a key in the UEFI BIOS. This identifies the device. That key will be unique to that device forever, so as you upgrade Windows that key is carried with it. The key no longer identifies a Windows version, it identifies the device.
This will be the case for probably 90% of every consumer device out there that gets Windows 10.
There are 2 exceptions. System builder OEM keys, where it is still limited to that device just like always, but the key is entered manually rather than stored in the BIOS. And then retail. Retail is the one people are getting all worked up about for no reason. Retail is not limited to a single device (although it is limited to only 1 install at a time) so retail keys updated to 10 will remain retail and therefore transferable.
So yes, it will mean limited to that motherboard for all devices where Windows is already limited to that motherboard anyway. Retail keys are the exception, but they are such a small fraction of the total market they haven't bothered to explicitly point that out. Much like they havent specifically pointed out how Business licenses will work.
Stop panicing. Do you have a retail version your planning to update?
im not panicking, just because someone says they've been thinking doesn't mean they panicking. if you had a thought/thinking what you class yourself as panicking? i don't think so...
anyway i be upgrading from the £25 win8 upgrade offer
i know all about oem / retail, and pre installed versions of win8/8.1 are tied to motherboard, win8/8.1 owm = retail if bought separate (not pre installed)
also win8/8.1 owm = retail if bought separate (not pre installed)
Your asking the same things that have been discussed countless times.
What did you upgrade to W8 from?
Basically, stop thinking of keys and devices as 2 seperate things, and instead think of them as one and the same.
i didn't ask anything in that post, i said i been thinking, asking and thinking are to different things
win7 oem so it'll be win8 oem > win10 oem... which i know....
but going by this http://www.microsoft.com/oem/en/lic...ensing-for-personal-use.aspx#fbid=PSDjAM_Hwb4 oem is not for personal use, well win8 oem was... but theres never been a windows 8.1 retail..
Theres always been a discrepancy between what's successfully activated and what's considered "licensed" by the terms and conditions. Its incredibly difficult (I.e. impossible) to police as it all comes down to who physically uses a device, which Microsoft can't track.
But as your coming from OEM your going to be limited by your motherboard anyway, so Windows 10 won't be any different to your situation with 7 or 8. But all this means is you have to phone the robot rather than activate online so its not a problem.
Ive got 3 Windows 7 retail licenses, an 8.1 with Bing OEM, and a 8.1 Enterprise all due to be updated so I think I'll have most bases covered :p
Windows 8 changed licenses
Windows 7 OEM pre installed and windows 7 OEM is tied to mobo.
Windows 8 and 8.1 pre installed OEM is tied to mobo,
Windows 8 and 8.1 OEM purchased is transferable.
They really ***** up calling it OEM and changing the licenses.
Ny windows upgrade you just applied the underlying license.
So you aren't going from win7 > win8 > win 10.
You're simply continuing to use your win 7 license, with what ever t&cs apply.
what i mean was because i upgraded from w7 oem to w8 it still = as oem non transferable because im upgrading from a non transferable license,
if i bought w8 oem then upgrade to w10 then that basically = as w10 retail..
Yep, upgrades always use the underlying t&cs,
So your win7 is your original key and as that's OEM, technically it's tied to mobo. Although 99% of the time, you'll have no issue phone activating on a different mobo.
My original key is win7 retail, from the cheap release offer so I'm fine.
Those who got win 8 OEM = essentially retail. Minor difference in licenses but nothing worth debating. They are totally transferable.
yeah it's w7 oem. which i have had for years, without issues
but tbh if i ever get issues with it i'll just buy the full license..
why did we get a new key for w8 upgrade?
That's how upgrades in the passed have worked.
New key doesn't change the fact it's an upgrade and adopts the license from the previous version.
Because the shift on how keys and devices are linked wasn't in place when 7 was released. It was still the tradition 'key per version' structure.
Windows 8 (or maybe 8.1, can't remember) was what changed the way keys and Windows versions are linked.
Basically, what you now own is a "Windows License" that's either transferable or not (depending on the complex various options to how you optained it). The version number is no longer relevent (although the branch is, i.e. Home, Pro, etc).
When you look at it like that you can see why Microsoft have done it. It brings it in line with how licensing for most other software works, especially corporate software, where you get upgrades included in the license. It also aligns with how Office 365 and things work (although that is a subscription rather than a one off payment, but its still "an Office License" rather than just a specific release of Office).
Microsoft have been, as usual, really **** at explaining what they are doing. But when you work it all out it makes sense.
i'm wrong!!! i just checked my w7 boxes that i bought for my pc and old laptop and they are both retail
i most of been thinking of vista which i have 2 oem copys
Although in that case you have to pay ongoing maintenance/subscription to continue to get updates or use.
I guess that will have to come at some point as they can't keep giving away new versions for free. Unlike Apple they still need to generate income from their O/S.
