Acer XB270HU - Worlds First IPS, 1440p, 144hz, Gsync
It might not bother you visibly to the naked eye but the phone has highlighted how bad these screens are.
For such an expensive monitor the bottom right corner should not be like that.
I agree completely. The QC on these monitors is shocking, hopefully when the new batch finally arrives these issues are a thing of the past.
That's true. Would you keep the monitor if it was like mine? I am not sure what to do. I am thinking of keeping it to be honest as it does not bother me that much so far and it could have been worse based on what people reported.
e: Do I need to do something in order to enable 144hz? Maximum I see is 120hz. The monitor is displayed as "Generic PnP Monitor" in Device Manager.
If you are happy with it then keep it. Personally I would be sending that back because of the bleed/glow and dirt behind the screen.
I just enabled gsync on mine in the nvidia control panel and games run at 144hz if you have the Gpu power to reach it.
Regarding the glow, give it a couple of days. The ones I had anyway, the glow reduced to the point of barely being able to see it on black screens. Hopefully be the same with yours.
Mine just had nasty backlight bleed problems and dead pixels
Thanks, hopefully it will get better in the next few days.
Do you need G-Sync enabled to get 144hz? At the moment I am on my laptop with 7970m CF and I don't see a way to set 144hz.
If I were you I would make sure you decide before your 14 days OCUK return are up as after that you will need to deal with Acer and thats not good.
Once I get my new PC up and running I will give this monitor a few days of normal use. If the bleed or that dirt bothers me, it will go back to OcUK.
So far I am quite impressed with the image quality. It is probably because it is my first 1440p monitor though.
And the waiting continues...
So. I spy with my little eye something beginning with.... ok I'm bored now.
Heard nothing from Acer whatsoever so far. I'm on the list for a swap as far as I know but clueless to anything else.
I took mine back to the shop almost 30 days after buying the monitor and they gave me my money back no questions asked. There was a dead pixel in the middle of the screen and dirt behind the screen in the left bottom corner. Acer are accepting them back for the dirt because it is an inherent fault in this first batch. I'd send the one shown in the picture above back because the bleed is shocking compared to mine and the dirt looks almost the same size and shape that I had behind my panel. It's about the size of a grain of rice and a faint brown colour.
Just wondering if its worth hanging around for the "new messiah" after seeing this...
Look at the bottom right corner... identical to my Acer return.. and this is on an exhibition model of the forthcoming Asus PG279Q...
Surely they must be using the same panel....
Where to go now?
OMG thats terrible. Wonder if they need to turn down the brightness to 15 :) You can see the glow sometimes when it displays an image.
Asus ROG Swift PG279Q WQHD 144Hz IPS Panel and G-sync
For my current and previous 2x29um65's and dell u2311h, it makes a massive difference. But yes "severe" bleed will not be "completely" removed by lowering the brightness
