Would love to know who actually used the word "port" first, only to then see it used so widely in the industry.
Runs amazing on Windows 10 using a 980 ti, was horrible on Windows 8.1
Any elaboration on 'amazingly'???
Does it suddenly maintain a solid 60fps without tweaking INI files to unlock anything over 30? Have the missing textures mysteriously returned and do we have more controls for customising graphics and mouse controls/fov???
I highly doubt 'amazingly' is the appropriate word here.
YEs please, does it still have huge frame drops when calling/using the Batmobile? Are you running on an SSD? What are your specs in general?
Honestly, I don't believe it looks better than the PS4 version, it's missing the ambient occlusion among other things the PS4 version has.
Bat mobile drops? No.
SSD? Yes. Samsung 830 250Gb that's also my boot drive.
Core i5 2500k @4.2ghz, 8gb DDR3, GTX780 6gb driving a 2560x1080 LG Ultrawide monitor which the game supports natively other than cutscenes which is pretty much par for the course.
Did I read earlier in this thread that you're running at 30fps?
The hate is way overblown this game still looks magnificent to me probably the best looking UE3 engined game to date.
I only have a single GTX970 but @ 4K is perfectly playable when you disable all Nvidia Gameworks features & have everything else maxxed out (disable AO on the desktop though that conflicts with the ingame AO scheme just like it did in Aliens Colonial Marines).
Gfx look very pretty the textures especially (make sure you do not disable the 30FPS limit as that prevents some textures from streaming in properly on a HDD) but the lighting FX on reflections look fantastic this game has a terrific atmosphere its an insane OTT reaction for WB to remove from sale just because its missing a few settings which can & will be put back in sooner or later
Gameplay wise this takes everything positive from Asylum & City then makes the scale so much larger & the batmobile as a co-op partner really adds a unique dimension to the gameplay you can do so much cool stuff with both working in combo with each other![]()
