Don
- 20 Oct 2002
- Oxfordshire / Bucks
scary watching your videos Ed
decided to put a few random videos together instead of dumping it all separately! will do it more often! still impressed with Virb's quality.
My poor heart! Bugger riding between vehicles like that. You track stand like a Pro though![]()
I know it's not the safest way but lets be honest if you want to make progress in london you gotta learn to filter ? I know the risks. Track stands, how did you know?
you've been stalking me or what?
Ah yeah, forgot about the APR. In that case, i'll be there this week. But will try and get to the bundy the week after. 7pm is quite a good time for me actually, can get back from work and get down there fairly easily i reckon.
I didn't really lie down. I drank a massive coffee then ate a scotch egg, a packet of super noodles, 4 bits of toast, some grapes and a Rowntrees Fruit Pastels ice lolly. #mybodyisatemple #recoverymatters
Then i cut the grass, did the strimming and edging and generally did all the stuff i've wanted to do to the garden but haven't been able to due to lack of summer.
you get used to it, it is quite a chance from the country lane cycling and tbh I don't feel safe there?
hahI know it's not the safest way but lets be honest if you want to make progress in london you gotta learn to filter ? I know the risks. Track stands, how did you know?
You'd need to check the bolt circle diameter (BCD) of your current crankset. Compact is 110mm, standard double is 130mm.
but other than that the widths are the same?
Overshoes are only so waterproof, at the end of the day water will get in the top! I suspect the winter ones would be very toasty in this sort of weather.
If you watch the video carefully you can see small side to side movements while the camera view remains perfectly horizontal. They stop once you have the position right![]()
I was attempting to do my full 11.5mi commute to work/home without putting my foot down! best I've got is 7 miles
